I'm in the middle of doing a 4.6 swap in my diff but i'm in need of more pinion shims. The shim between the pinion gear and inner bearing. Does anyone sell them or has anyone used shims from some other pinion? I'll take any help I can get, thanks!
top of page
bottom of page
# 38125 took me a decent ammount of digging to find them when I changed my r&p as well. Good luck!
should be able to steal them out of another r200 diff if theres anything in junkyards locally around you
