Early 2014 to current with my chassis, modifications, wrecks , learning as i go & driving.Big inspiration to some of the locals i met in 2012/2013 that played a huge part in my styling, function and how it got me hooked.
I had zero idea of where this car would car would take me, people I've met, road trips taken, being on the side of the road laughing fixing the car with friends at 2am.
Purchased late 14'-15' and immediately became a daily driver.
Here's a spec list of the car current day December 2023
2004 Lexus IS300 (factory manual)
Engine
1JZGTE vvti - fresh timing and seals during swap
Emu black full standalone by Ecu Masters
Tweaked custom harness engine harness
Audi R8 coils
2JGTE water pump w/ polished pulley
Serial9 solid mounts
UpFab top mount turbo manifold
Borg s257sxe .82 turbocharger t51r mod
Turbo smart hypergate 45mm external waste gate
FunkMotorsports Blanket
Mac valve boost solenoid
Radium valve cover fittings 10an
1UP custom IS vented catch can w/ drain
-10an coolant return from cylinder head
-4an turbo feed & 10an drain
Driftmotion intake thermal gaskets
ChaseBays Power steering Reservoir kit
6an 10 row p/s cooler
Tons of heat sleeve/protection all Raceflux brand
Whp Oil pressure, fuel pressure and IAT GM sensor
Koyo Radiator triple pass with koyo high psi cap
Custom shroud with dual 3200 CFM race fans wired on standalone thermostatic harness with relay box
BTI can gauge with electronic boost control & boost knob for tunes/boost levels.
Tuned by Sound Performance Bensenville IL
Fuel System-
-6an feed and return- all raceflux fittings & vibrant line (e85 rated line)
Aeromotive FPR w/radium mechanical gauge on fpr
Injector Dynamics 1050x injectors
Aristo hanger w/ Aeromotive 340LPH pump
Gm flex fuel sensor
Drivetrain-
Jzx110 verossa r154 (low mileage) shifts beautifully
Verossa shifter housing
Cubespeed billet aluminum shifter
-3an SS clutch line
Vertex shift knob
OS giken 559D twin disc clutch
Aisin slave and new inspection plates
4” aluminum 1pc driveshaft with 3150 joints
3.9 welded
Exhaust-
3” down pipe/3” piping
New rubber hangers, all v bands.
Vibrant bellows (flex)
Vibrant Ultra Quiet & Vibrant bottle resonator
4” SS blast pipes
Suspension-
Dmax jzx100 adjustable caster arms
New FLCA LH+RH
Stance xr1 22k/18k swifts
Jzx100 front uppers
Serial9 ak49 knuckles
Shortened spindles 35mm
Gs300 outter tie rods
Kfd rear arm set (LCA,toe,trac)
Figs solid rack bushings
Figs subframe poly insert subframe bushings
Powered by max solid diff bushings
Hotckis front/rear sway bars
Exterior-
BN sports kit
Don musk overfenders (front+rear)
Sxe10 Ganador mirrors with blue tint glass
OE stock hood
Altezza gita grill
Altezza tail lamp covers
Black housing headlights with LED low beams
Wheels-
17/18 vskf
17x9.5 et25 +30mm spacer
18x11 +10
— 18x10.5 +12 cr lie spares (4)
215/45/17 falken rtk steers
235/40 kenda kr20a
Interior-
Buddy club p1 seat
Sparco passenger seat
01 dash/console swap (non sticky)
Chasebays hydro with serial9 wilwood dual caliper
Double din. Upgraded basic speakers.
Steering hub with vilante leather wheel 350mm
25% tints all around
5% rear windshield
Battery relocated to trunk with waterproof breaker. 1/0 battery wire with fuel pump relay mounted on battery box. Billet aluminum tie down and bracket
10g fuel pump wiring from battery to fuel hanger Power and ground controlled for pump via standalone.
2004 factory 5 speed, 236K stock GE. Became the best daily and winter fun car with a set of blizzaks. Only modification when purchased used was a set of CX racing coilovers.
no real hiccups rest of 2022 except lack of tires.I did have a event where I entirely broke both oem engine mounts, upgraded to Serial Nine solids. Thanks Josh Buado for the help on the lift at the shop getting those in.
