K24Z3 Miata Build List:
EXTERIOR:
Refinished undercarriage
OEM hardtop w/defrost
R Package rear spoiler
CarbonMiata flush GV rear panel
-OEM rear finish panel and tail lights (backup)
Replica Mazdaspeed a-spec type 2 front lip
-GV Style ebay lip (backup)
Replica GV style rear arch side "spats"/skirts
FiberglassMafia fender flares
CCP Fabrication Fiberglass Kswap hood bump
ENGINE AND TRANSMISSION:
SUSPENSION AND STEERING:
DOOMFAB Steering knuckles (hit me up if you're interested in a pair)
BC DS front and BR rear coilovers
Destroy or Die front LCA
Destroy or Die rear LCA (shortened)
De-powered rack
Steering rack spacers
Racing Beat front sway bar
OEM rear sway bar
FlyinMiata endlinks (front)
949 Racing endlinks (rear)
Reinforced subframes
Energy Suspension bushings
BRAKES:
OEM calipers, rebuilt
Centric Parts coated rotors
HAWK HPS pads
FUELING:
Walbro 255 lph pump
Aeromotive FPR
Karcepts fuel rail
Custom fuel lines
OEM fuel filter
Stock 310cc injectors (will upgrade to RDX eventually when I buy a new IM drilled for them)
COOLING:
Koyo radiator
SPAL fans
Custom aluminum radiator tubing
AdvanceAutosports Coolant Gauge Adapter (large)
INTERIOR:
AdvanceAutosports spec miata cage, graphite metallic paint
NA6 black dash
Black OEM carpet
Custom dash cover
CROW harnesses
Buddyclub P1 driver seat
eBay passenger bucket seat
WorksBell slim hub
NRG quick release, idk the model... 2,2.5?
Nardi black edition wheel, 350mm
VERMIN horn button, from Revlimiter (check him out!)
P2M checkered mats
TorqueSolutions delrin shift knob
"Miata" embroidered shift boot
Late NA/NB dome light
LED visor lights
DDM Works radio surround (upside down)
NA6 oil pressure gauge in cluster
Cluster odometer set to 000000 for swap
Sony BT headunit ("beep-boo-beep" fanboy)
OEM Miata sunglasses holder
ELECTRONICS AND GAUGES:
WHEELS AND TIRES
SSR Longchamp x-r4, 14x6.5
Rays GramLight 57DR, white, 15x8
Work CR Kiawami, white, 15x8
OEM miata 7 spokes, OEM silver and some white sets, 14x...6?
Front Tires: Accelera 651, Federal 595
Rear Tires: Ironman imove, accelera alpha, accelera phi
Quick alignment from this weekend. I have the PACO camber/eccentric bolt locks, which unfortunately limit the adjustability of the camber bolts. Even when trying every orientation combo possible, the “smiley face” teeth wouldn't fit into the eccentric locks to match caster AND camber, so this was the best we could do. 949/SuperMiata camber bolts ordered for the next alignment so we can dial everything in to what we want instead of what we can get.
Focus was to reduce caster from the previous alignment which was around 6.5 degrees. I could go down as far as 2 degrees caster, but didnt want to overshoot it and have the opposite problem of zero self steer.
The camber was also reduced from 6ish degrees on the previous alignment to left say an AVG of -5.0. I moved the newer LBJs to the innermost position on the destroy or die LCAs instead of the middle position. My new knuckles I welded up dont have as much ackerman correction as the old “angle adapters” so the LBJ was moved in to ensure the existing tie rod length was “okay”. If I remember correctly the destroy or die LCAs at the inner most setting are still +10ish mm on track width from OEM LCAs.
I can deal with the camber difference for this event. Not sure what happened to the rear LH toe… it was perfect before we aligned front and re swept for caster. Oh well.
I’ll follow up to this and that “non power steering drift alignment” thread after this weekend with results. From the drive home and some more gentle break in miles, it feels like it should be enough… but we will see.
