I've been in a Z32 since 2007. I'm currently on my 3rd chassis, mostly because my previous two chassis have been rear ended and totalled. Currently I both road race and drift my car. Have been since I've had my first Z. Do both for fun but also am one of the organizers for Nissan Challenge, so if you have a Nissan you want to time attack in Socal, hit me up!
ASB 2010
2016
New chassis is a culmination of parts and experience/ knowledge from over the years and the previous two chassis. Here it is in it's current form:
1991 Nissan 300ZX 2+2
Engine/ Drivetrain:
280k mile NA VG30
Stock bottom end
Dual MAF/ Dual JWT intakes w/ Selin translator
Injen intake pipes
Bored OEM throttle bodies
480cc S15 injectors
JWT 400+ cams
BDE adjustable VTC and exhaust cam pulleys
Stillen headers
2.5" Resonated test pipes
3" Veilside Evolution exhaust
UR underdrive crank pulley
SpecialtyZ tune
SpecialtyZ Sport 6 puck clutch
SpecialtyZ Segmented flywheel
Z1 steel driveshaft
ATS 2 way LSD with WPC treated disks
4.4 final drive
Greddy diff cover
Suspension/ Brakes:
Powertrix PTX valved Ultralite coilovers
Swift 10kgmm spreings front and rear
Swift 1.5kgmm help springs front and rear
Powertrix front upper control arms
Powertrix sway bar endlinks front and rear
Powertrix CF tension rods
SPL outer tie rods
Powertrix tie rod spacers
Powertrix RUCA
SPL Toe arms
SPL Rear Traction Arms
GK Tech subframe reforcement kit
SPL Solid subframe risers
SPL Solid diff mounts
Supra MK4 calipers with Powertrix adapter
Stoptech rotors
Endless CCRG brake pads
Endless RF650 brake fluid
GMR 1200R front wheels 18x10.5 -3
Desmond Koenig rear wheels 18x10.5 -31
Bridgestone RE71RS 255/35-18 tires all around
Body/ Interior:
Mission front bumper
Racebred chassis mount splitter
TwinZ hood
OEM kouki side skirts
TwinZ side splitters
Ganador mirrors
Mission 50mm rear over fenders
My own roof spoiler
AB Flug Type 3 rear spoiler with adjustable CF blade
Recaro SPG Racer XL driver seat on Bride adjustable rails
Recaro SR2 confetti passenger seat on Bride adjustable rails
Sabelt 350mm dished steering wheel
OG Nismo horn button
OG Nismo shift knob
Kenwood double din headunit
Speed hut gauges (oil pressure, oil temp, water temp)
As for plans for the car, I've had a 1JZ I've had for years. Plan is to eventually get it into the car.
Blue Moon assembled bottom end. Tomei rods, CP pistons WPC treated everything. Rebuilt head. Slowly working on it and getting what I need to get it into the car eventually. But for now, I'm enjoying the car as is on the street as the day to day car as well the the car I take road racing. I've had it running for the past 2 years and it's been working great without much issues. I am hoping to take it to more drift events with friends.
I saw this at a meet in Anaheim while visiting LA and couldn't walk away from it! Stoked to see it does cool stuff too.
