1992 Miata
Stock block turbocharged with s15 t28 10psi
A lot of stuff done over the past 4 years, really want to start a build thread from here on out and also updating with what I've done over the past years as best I can recall to provide some information to people and also because this car means a good bit to me. Enjoy
ENGINE/DRIVETRAIN
Stock 1.6 engine
Kraken top mount cast manifold
Kraken turbo elbow and 3 inch to 2.5 inch downpipe
S15 t28 turbo
Kraken intercooler piping
FMIC.EU intercooler
Mamba adjustable and clockable iwg
ISR titanium turbo blanket
FM coolant reroute w/ turbo coolant lines
323 GTX turbo pcv valve (catch can in between)
BMW vTPS w/ miata solutions billet tps bracket
MSPNP2 ECU
Deatschwerks 700cc injectors
Deatschwerks DW200 fuel pump
FM Koyorad crossflow radiator
OEM fans wired in parallel
Fablab brake master heat shield
Oil filter sandwich plate
FM Stage 1 clutch
ACT Streetlite flywheel
Innovative 60A poly motor mounts
Racing beat 2.5in test pipe
2.5in stainless exhaust from test pipe to 4" outlet
Uras D1 slant tail downturn tip
NB 6 Speed
NA8 driveshaft
NA8 4.1 welded diff
Superpro poly diff bushings
NA8 one piece axles
SUSPENSION
Megan racing 8k/6k coilovers
Destroy or die FUCA
Destroy or die FLCA
Destroy or die shortened RLCA
Fablab cut knuckles
Destroy or die front extended brake lines
Nissan stanza/axxess outer tie rods
Superpro ps rack bushings
Hawk HPS street front pads
Project Mu D1 spec rear pads
ARP wheel studs up front
EXTERIOR
PS Duce front bumper
PS Duce side skirts
PS Duce rear bumper
NUE Type 2 trunk spoiler
M2 1028 rep mirrors
Modelodrive vented hood
Depo smoked turn signal lamps
Jass performance low profile headlights
Altezza Chrome Tail Lights
Work Meister 2p 15x7.5 +4 w 20mm spacer up front
Work Goocars 15x9 +0 rear
Work Emotion Kiwami 15x8 +5 rear
Work Euroline FS 15x8 -4 & -16
Car is sprayed Nissan KR4 Sierra Silver Metallic
Side skirts have tropical glitz starlight metal flake lol
INTERIOR
Nardi classic 330
Works bell wheel hub
Yours Sport white and blue veilside font cluster
Shirtstuckedin shift knob
Cusco? silver drift button
Shirtstuckedin driving force v2 black seat
Bride type FO bracket
Bride Zeta II black seat
Shirtstuckedin seat side cushions/pockets
Broadway 300mm blue glass mirror
Custom fire extinguisher bracket
Hard Dog harness bar
Braum 4pt harness
Chikara motorsports floor mats
Dash mat
2 gauge pod a-pillar
AEM wideband gauge
Blitz old logo 1.5bar boost gauge
Defi advance bf water temp gauge
Defi advance bf oil temp gauge
Defi advance bf oil pressure gauge
Defi advance controller
Kenwood single din
Kenwood door speakers
Kenwood under seat sub
Good 00s style. 2p miesters are undefeated
