S13 sr20det rebuilt at 184,000kms
Wiseco SR20 Pistons. K556M86AP
-Manley SR20 H-beam rods. man14023-4
-ACL Thrust washer. acl1t2964-std
-ACL SR20 Main bearings. acl5m2964h-std
-ACL SR20 Rod Bearing. acI4b2960h-std
-ARP SR20 Head studs. arp102-4701
-Valve Seals. gsc1052
-tail mv-r 44mm wastegate
-gk-tech 7 layer exhaust manifold gasket
-mazworx ss series top mount manifold
-mazworx 3" downpipe
-mazworx mv-r wastegate dump pipe
-mazworx sr20 top mount turbo lines- garret g series turbo with s14 water neck
Garrett g25-550 .72AR (858161-5002S+740902-0069)
-Greddy baffled oil pan
-Greddy magnetic drain plug
-Greddy bov
-P2M alternator
-S14 water neck
-ISR water pump
-740cc deatschwerks injectors
-custom fabbed catch can with 10AN fittings
-WHP Boost Solenoid
-Part shop max intercooler, couplers, custom piping
-ISIS rad with 2 electric fans.
-Ordi Programmable ECUMASTER Classic
-s13.4 valve cover mod
-Aem x series oil pressure and water temp gauges
Suspension
Advan rg2 17x9/9.5+22
-bc coil overs 8kg 10kg
Full adjustable rear arms- upper and lower control arms, toe arms, camber arms etc
-welded diff with z33 axles
-1pc aluminum driveshaft
-front) subframe reinforced +rack moved
-front) 55mm extended and reinforced lca
-Front) adjustable caster arms
-front) cut knuckles
-custom inline "hydro" handbrake set up
